Android keep restarting
chhetrix
My android phone from VOX company keep restarting itself and I already tried factory reset but still restarting 1000 times . At first I thought problem coming from memory card or from SIM but after removing android again goes to restarting loop.
Tons of thanks if any of you can solve this problem.
Hello and welcome to Android Forums, chhetrix. :)
Does it do this only while you're using it? Or does it restart whether you are touching it or not? If you are lucky it's a simple problem like a loose or dirty battery connection. If the battery comes out of your phone, use a little alcohol on a q-tip and clean the connections, and make sure the battery seats tightly with good contact.
If that doesn't fix it, and you've already reset the phone, you might have internal hardware problems. You'll need to send it in for repair. :(
