I have popup window which is a circle and I want it to be partially out of screen bounds. To invoke window I used: `popup.showAsDropDown(imageButton, OFFSET_X, OFFSET_Y);` And it should looks like this:
To clip a view I used: `popup.setClippingEnabled(false);`
And it works, it looks as I expect on devices with API level below 21...
Unfortunately, on android L (lollipop) it looks like this:
Circle is clipped on top, but on right side it just come to the edge of screen. Any ideas how to solve this problem?
I attach source code in which I invoke popup window
Java:
private void showPopup(final Activity context, ImageButton imageButton ) {
// Inflate the popup_layout.xml
FrameLayout viewGroup = (FrameLayout) context.findViewById(R.id.popup);
final LayoutInflater layoutInflater = (LayoutInflater) context
.getSystemService(Context.LAYOUT_INFLATER_SERVICE);
final View layout = layoutInflater.inflate(R.layout.popup, viewGroup);
layout.startAnimation(range_animation_start);
layout.measure(View.MeasureSpec.UNSPECIFIED, View.MeasureSpec.UNSPECIFIED);
int popupHeight = layout.getMeasuredHeight();
int popupWidth = layout.getMeasuredWidth();
// Creating the PopupWindow
final PopupWindow popup = new PopupWindow(layout);
popup.setContentView(layout);
popup.setWidth(popupWidth);
popup.setHeight(popupHeight);
popup.setFocusable(true);
// Some offset to align the popup a bit to the right, and a bit down, relative to button's position.
int OFFSET_X =getResources().getDimensionPixelOffset(R.dimen.width_offset);
int OFFSET_Y = getResources().getDimensionPixelOffset(R.dimen.height_offset);
// Clear the default translucent background
popup.setBackgroundDrawable(new BitmapDrawable());
// Displaying the popup at the specified location, + offsets.
