superzaki
Hi and hello everyone, i want to make a live wallpaper in which the wallpaper should move in a parallax way like the effect i made in the video bellow (used Adobe After Effects),
the problem is that i am no programmer and i know nothing about android programming,
what i want is:
-swiping the screen should move onward and backward the wallpaper
-shift to another scenes (which i will make if i will figure out how to make the app) after 4s off motion (or less)
here is the video
https://www.youtube.com/watch?v=32_B-7pG07c&feature=youtu.be
original image
* i have an idea only if i can make it work:
-1-
- convert all these projects to a combined HD vid.
- like on VLC player, pause and moving the cursor forward and backward gives a total control over the motion on the video.
- translate these "mouse-grabbing" gesture to swipe over an android terminal ... and THAT what i don't know how to do.. any help with my case would be appreciated,
last and not least, please excuse my English
OR
-2-
-convert the video created earlier to frames and use it to generate a flawless image movement
PLEASE HELP !
greetings from Algeria !
what i want is:
here is the video
original image
-1-
OR
-2-
PLEASE HELP !
