Help Android market applications are not downloading
sudipta das
I am unable to download any application from the android market. Though, Google mail is still working in my phone. Error message shown is "Download unsuccessful, Please try later." Please suggest what to do? I am using vodafonemobileconnect as active data profile. I have already talked with vodafone customer care executive, and she has confirmed me that my data profile is active and they have not found any problem. I am quite confused.
i think this is the prob. of vodaphone network.if you are from india,then try Bsnl 3G.Another option is you can use market enabler which is available in the market or download it on pc.it virtually change the sim setting which you can restore during next boot.
i am using LG GT540. the problem is i am unable to download any android software, its showing download unsuccessful. i am using uninor network. i called up the uninor customer care but they said the problem is with phone. So please suggest me what to do now. i have to go to LG mobiles service centres for downloading the softwares?
Friends, tonight I have solved the discussed problem. Yes, idhbar, I am from Kolkata, West Bengal, India and I am using Vodafone sim. In my locality Vodafone 3G services will be officially available from 31st of Octover, 2011, though it has already been launched within the Kolkata city metropolis. Same case with Airtel, Aircel, etc.
Anyway, coming to the main point, let me share with you all that how we all can upgrade the firmware version from the default 1.6 Donut to 2.1 eclair. I am writing the steps serially:-
1) If you have a personal computer with Broadband Internet connection then go to Internet Explorer or Mozilla Firefox, I mean your default browser and in the URL box paste or write down the following web address and click ENTER.
http://www.lg.com/uk/mobile-phones/all-lg-phones/LG-android-mobile-phone-GT540.jsp
2) From the SUPPORT segment, choose OS UPGRADE and LG Mobile Support Tool.
3) When LG Mobile Support Tool dialog box pops up, go to OPTIONS and HELP.
4) Click on this and you will find COUNTRY and LANGUAGE. Select the country you live in and also select the main language used over there.
5) In the same dialog box you will get another option named INSTALL USB DRIVERS. If you have not installed them already in your PC, then immediately install them because without them you can not do anything.
6) Then click on HELP from the OPTIONS nd HELP, now you will see a big page infront of you with a "SEARCH" option. Just click on it and you will see a table of contents explaining how to upgrade the OS of your phone.
7) In the 4th column you will see the procedure of LG GT540 OS UPGRADATION PROCEDURE which was announced on 17/09/2010.
8) Now just blindly follow the instructions written there. Your phone firmware will be soon upgraded from 1.6 to 2.1 without any hassle. It will take some 1 hour and 10-15 minutes to complete the process.
N.B. Keep your phone connected via USB data cable provided with you with the phone in the sales package and please do not become impatient to disconnect it or to take out the battery or to use the phone in any means. Another tip, before doing this charge the battery of this phone fully because the process might consume a lot of battery power, if it drains in the middle, there might cause some serious and severe damage to the phone itself. So be cautious. One more thing, while installing the USB drivers, keep your phone disconnected from your PC.
There is no need to drop in your nearest LG SERVICE CENTRE. At your home in your convenient time slot you can do this and believe me you need not be a tech-savvy person. Just after doing so you can back up your applications from ASTRO FILE MANAGER which will be required to re-install from the Android Market. Believe me friends, you will find it much easier and there will be no such problems as we have been discussing with in this thread and, moreover, LG OPTIMUS GT540 will be a new smartphone again. Last but not the least, just for satisfaction, go to SETTINGS from the home screen, then go to ABOUT PHONE, tap on it and just check out the last option that is, SOFTWARE VERSION, you will see this - GT540-V20c-DEC-03-2010 and above it you will also see the FIRMWARE VERSION, that is 2.1-update1.
Enjoy and rock.....
Hope my post will help those who lack profound technical know-how loke me. Please comment......:)
