Help Android Market not showing installed apps
I did a factory reset on my phone and restored a lot of the apps + settings I previously had installed with Titanium Backup. The apps aren't showing under "My Apps" in the Android market. If I navigate to the app in the market and click "Free" or "Purchased" it re-installs the app and overwrites the other one (keeping all settings) and shows up as being installed. If it doesn't show up under "My Apps" I assume I won't be notified when it's updated.
Is there anyway to link the apps up the market place so I don't need to re-install every app?
Download a new app from the market (choose any free app) then delete it after. You should get your
"my apps" list back by doing so. It worked for me.
go to settings->applications -> manage applications -> market
then delete cache
that should do it
