Szadzik
Extreme Android User
Are you sure?
What could be wrong with the phone anyway?
Maybe its carrier. I'll contact them if this don't get better soon.
No one can be sure here. Just making guesses trying to think what else may be affecting this.
Are you sure?
Yes,I used the Universal Androot.
Chances are that it is a problem with the ROM, or you have accidentally altered or deleted a file needed for it.
I suggest starting a thread in the Milestone Root section for help from those who know the Milestone better than I do.
Kratos
Kratos
The fastest way would be to flash an SBF file and start from scratch.
When you alter system apps and then do a hard reset the system apps you removed do not get replaced.
In order to replace a missing app just reflash it.
flash an SBF file?
I'm not very familiar with that.
I was having issues with the market on Friday. Same thing it would timeout downloading my updates or just pause the download. I went into the settings and cleared the market cache tried again and it worked. Been downloading apps throughout the weekend no problem.
Maybe worth a try
