Android Market Problem
D
Deleted User
Guest
Ok, everything was going fine and I do not know what went wrong.
But the Market app started giving "Package Invalid Error"
So, I, uninstalled the update by going to Settings->Applications->Manage Applications->Market
But this didn't help too much. After a while, the market started saying "Network Error"
And again, I, decided to remove the market and copy the new version.
Using a root file browser, deleted the .dex file and the com.android.vending folder and replaced Vending.apk, gave permissions rw-,r--,r--
And rebooted.
Now the market is missing.
I think I have removed Market from start up list using System Tuner.
So, is there a way to fix this problem and get a working Market app?
EDIT : Just saw user pj_a70 is also experiencing the same (or almost the same) problem.
Help is really appreciated
Thanks.
Sorry for the post.
Replacing the Vending.apk and Clearing the dalvik cache from recovery solved the problem
