CampSoup1988
I have the Kyocera Echo, recently I had my phone replaced after it would not install the firmware update (even after tech support resetted the phone numerous times, and different ways). I then installed the apps onto the phone using My Library on Android's Marketplace (I had way too many apps to search for each one individually) Now, I noticed when I went to Market Place (on the phone) to check if any of them have updates, and none of them are listed.
What can I do to get them listed so I would know when they are updated?
Thank you,
CampSoup1988
Thank you,
CampSoup1988
