I have emailed Zte to see if the grand x max plus will get andriod 6.0 and Zte said this...but idk guys what do you guys think? Will we see the grand x max plus getting android 6.0 marshmallow?
I hope they do, cause I really like my phone. Which BTW...did anyone update their phone to 5.1.1 and experienced some issues? Like slow videos or clicker noise when changing camera from back to front??
Is there a fix for this yet? I thought adding more RAM through a SD card might help. Also thought that running a your custom ROM might make a difference?Only Video lag. Otherwise nothing else.
HMT has an alpha version of CM 12.1 up and is waiting on users to report info on the performance.Had this pop up on my zte grand x max + this morning. Is it the marshmallow update?? Anyway we can get another pre-rooted flashable rom Mastercheif87?
Maybe later I'll port 13 but main goal is RR.HMT has an alpha version of CM 12.1 up and is waiting on users to report info on the performance.
Have you flashed CM 12.1 to yours yet? I am seriously just thinking of taking the plunge and doing it myself and reporting the info onto your thread. I am a noob but I know how to follow directions.I honestly have no clue if the Alpha will help, But Force GPU Option helps.
