Android Multitasking issue
  • Start date Start date
A
Android Question
Guest
Hello,
i have an issue in multitasking on my android phone.
when i open an app and leave it in the background to open another app.
when i reopen the first app. the app restart.
For example, if i was playing a game and put the app in the background to check my messages. when i reopen the game it restart and i loose all my unsaved changes.
Anyone has experienced the same issue?
Carl
Phone: Samsung Galaxy S3
Model: GT-I9300
Android Version: 4.1.2
Android has a built in task management system which will shut down apps when available memory gets low. If you have too many apps running at once, this could be the issue. Alternatively, if the game is not coded correctly, it may cause that problem as well. If you d of have too many apps open, you might try emailing the developer and seeing what they say.
Hope this helps!
