I downloaded android navigationdrawer project from HERE
And i wanna change ImportFragment to activity and set it in Drawer?
Please if can anyone help me
fm.beginTransaction().replace(R.id.content_frame, new ImportFragment()).commit();
Intent i = new Intent(this, ImportActivity.class)
startActivity(i);
public class first extends AppCompatActivity {
setContentView(R.layout.first);
Toolbar toolbar = (Toolbar) findViewById(R.id.toolbar);
FloatingActionButton fab = (FloatingActionButton) findViewById(R.id.fab);
fab.setOnClickListener(new View.OnClickListener() {
[USER=1021285]@override[/USER]
public void onClick(View view) {
Snackbar.make(view, "Replace with your own action", Snackbar.LENGTH_LONG)
.setAction("Action", null).show();
DrawerLayout drawer = (DrawerLayout) findViewById(R.id.drawer_layout);
ActionBarDrawerToggle toggle = new ActionBarDrawerToggle(
this, drawer, toolbar, R.string.navigation_drawer_open, R.string.navigation_drawer_close);
drawer.setDrawerListener(toggle);
toggle.syncState();
//NavigationView navigationView = (NavigationView) findViewById(R.id.nav_view);
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout
xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
app:layout_behavior="[USER=696546]@String[/USER]/appbar_scrolling_view_behavior"
tools:showIn="@layout/app_bar_main">
</RelativeLayout>
<android.support.design.widget.CoordinatorLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:fitsSystemWindows="true"
tools:context="com.example.sasor.tst.MainActivity">
<android.support.design.widget.AppBarLayout
android:layout_height="wrap_content"
android:theme="[USER=19691]@Style[/USER]/AppTheme.AppBarOverlay">
<android.support.v7.widget.Toolbar
android:id="@+id/toolbar"
android:layout_height="?attr/actionBarSize"
android:background="?attr/colorPrimary"
app:popupTheme="[USER=19691]@Style[/USER]/AppTheme.PopupOverlay" />
</android.support.design.widget.AppBarLayout>
<include layout="@layout/content_main" />
<include layout="@layout/first" />
<android.support.design.widget.FloatingActionButton
android:id="@+id/fab"
android:layout_width="wrap_content"
android:layout_gravity="bottom|end"
android:layout_margin="@dimen/fab_margin"
android:src="@android:drawable/ic_dialog_email" />
</android.support.design.widget.CoordinatorLayout>
01-22 10:30:12.718 358-678/? W/ActivityManager: in case of changing top-activity!![com.example.sasor.tst]
01-22 10:30:12.718 358-678/? I/ActivityManager: START {cmp=com.example.sasor.tst/.first u=0} from pid 24217
01-22 10:30:12.808 24217-24217/? D/AndroidRuntime: Shutting down VM
01-22 10:30:12.808 24217-24217/? W/dalvikvm: threadid=1: thread exiting with uncaught exception (group=0x410da2a0)
01-22 10:30:12.808 24217-24217/? E/AndroidRuntime: FATAL EXCEPTION: main
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.example.sasor.tst/com.example.sasor.tst.first}: java.lang.NullPointerException
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2073)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2098)
at android.app.ActivityThread.access$600(ActivityThread.java:138)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1204)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:137)
at android.app.ActivityThread.main(ActivityThread.java:4872)
at java.lang.reflect.Method.invokeNative(Native Method)
at java.lang.reflect.Method.invoke(Method.java:511)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:790)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557)
at dalvik.system.NativeStart.main(Native Method)
Caused by: java.lang.NullPointerException
at com.example.sasor.tst.first.onCreate(first.java:23)
at android.app.Activity.performCreate(Activity.java:5191)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1082)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2037)
01-22 10:30:12.818 358-16492/? W/ActivityManager: Force finishing activity com.example.sasor.tst/.first
01-22 10:30:12.818 358-16492/? W/ActivityManager: Force finishing activity com.example.sasor.tst/.MainActivity
View myView = findViewById(R.id.toolbar);
Toolbar mtoolbar = (Toolbar) myView.findViewById(R.id.toolbar);
setSupportActionBar(mtoolbar);
package com.example.sasor.myapplication;
import android.os.Bundle;
import android.support.design.widget.FloatingActionButton;
import android.support.design.widget.Snackbar;
import android.view.View;
import android.support.design.widget.NavigationView;
import android.support.v4.view.GravityCompat;
import android.support.v4.widget.DrawerLayout;
import android.support.v7.app.ActionBarDrawerToggle;
import android.support.v7.app.AppCompatActivity;
import android.support.v7.widget.Toolbar;
import android.view.Menu;
import android.view.MenuItem;
public class MainActivity extends AppCompatActivity
implements NavigationView.OnNavigationItemSelectedListener {
@Override
setContentView(R.layout.activity_main);
setSupportActionBar(toolbar);
@Override
toggle.syncState();
navigationView.setNavigationItemSelectedListener(this);
@Override
public void onBackPressed() {
if (drawer.isDrawerOpen(GravityCompat.START)) {
drawer.closeDrawer(GravityCompat.START);
} else {
super.onBackPressed();
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.main, menu);
return true;
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
//noinspection SimplifiableIfStatement
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
@SuppressWarnings("StatementWithEmptyBody")
@Override
public boolean onNavigationItemSelected(MenuItem item) {
// Handle navigation view item clicks here.
if (id == R.id.nav_camera) {
// Handle the camera action
} else if (id == R.id.nav_gallery) {
} else if (id == R.id.nav_slideshow) {
} else if (id == R.id.nav_manage) {
} else if (id == R.id.nav_share) {
} else if (id == R.id.nav_send) {
return true;
<android.support.v4.widget.DrawerLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:id="@+id/drawer_layout"
tools:openDrawer="start">
<include
layout="@layout/app_bar_main"
android:layout_height="match_parent" />
<android.support.design.widget.NavigationView
android:id="@+id/nav_view"
android:layout_gravity="start"
app:headerLayout="@layout/nav_header_main"
app:menu="@menu/activity_main_drawer" />
</android.support.v4.widget.DrawerLayout>
tools:context="com.example.sasor.myapplication.MainActivity">
android:theme="@style/AppTheme.AppBarOverlay">
app:popupTheme="@style/AppTheme.PopupOverlay" />
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:paddingBottom="@dimen/activity_vertical_margin"
android:paddingLeft="@dimen/activity_horizontal_margin"
android:paddingRight="@dimen/activity_horizontal_margin"
android:paddingTop="@dimen/activity_vertical_margin"
app:layout_behavior="@string/appbar_scrolling_view_behavior"
<TextView
android:text="Hello World!" />
</RelativeLayout>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_height="@dimen/nav_header_height"
android:background="@drawable/side_nav_bar"
android:gravity="bottom"
android:orientation="vertical"
android:theme="@style/ThemeOverlay.AppCompat.Dark">
<ImageView
android:id="@+id/imageView"
android:paddingTop="@dimen/nav_header_vertical_spacing"
android:src="@android:drawable/sym_def_app_icon" />
<TextView
android:text="Android Studio"
android:textAppearance="@style/TextAppearance.AppCompat.Body1" />
<TextView
android:id="@+id/textView"
android:text="android.studio@android.com" />
</LinearLayout>
