Android on a cloned iphone
Ares1
hello
some weeks ago i bought me i cloned iphone from china
it was a 70$ cellphone, problem is.. it's fully running on Java.. and i want to put android on it. it's possible to connect to my macbook and delete/add folders to it.
is there a way to delete everything on it and just place android on it? and how do i start doing that?
here's my cloned phone
TinyDeal - 2 SIM 4 Band 3.2 JAVA TV Email Mobile Cell Phone
good luck! you need to be a pretty good dev... and reprogram a lot to make it work with the hardware! rebuild the kernel..
If windows run on Mac, I think android will run on iPhone too. And the fact that the iPhone is cloned, it means you can just reprogram it that's if you are a witty developer.
