Are you referring to Android-X86, run Android on a PC? How did you install it?
Installation - Android-x86 - Porting Android to x86 Also note if you choose to format to fat32, you will see a warning that android cannot save data to fat32. You can still proceed to install, but the installed android system will work like a live cd system. That is, all data will lose after power off. Therefore we do not recommend to install Android-x86 to a fat32 partition.
