Help Android Op. System help.
Recently purchased a Samsung Galaxay S which had the default Android on it.
Yesterday I decided to Upgrade it to 2.3.3 Using Odin considering Kies was not recognising a new update was available.
After Upgrading the Battery life has been horid, Actually changing the battery Stats (Efforts to reset these haven't been succsesful) and the presentation its self look tacky and glitchy.
My Question is, should I just install the original Android 2.2.1 or is there a stable and working 2.3 (gingerbread) update which you could reconmend.
Aka. Which one is the best?
