Help Android OS 4.3 Passing Unwanted Parameters
krazybob
Recently my S3 was forced to take an upgrade, not that I woulds hjave likely said no. But it rearranged my screens, removed the Settings icon (moved it into Applications) and a host of other things you all likely have found. But it also has decided to pass unwanted parameters to applications.
I have ConnectBot and JuiceSSH. Both insist on accessing the last server I accessed. I have a lot of servers and I can see no way og choosing. Before the forced upgrade I was able to build a menu. Not anymore. I get the last accessed and only. I have to ssh into that box and then ssh into what I want.
How can I either return these to normal or at least remove the parameter being passed?
Thank you in advance.
KrazyBob
