B bead5 Lurker Sep 23, 2014 #1 Can I install android system in my desk top computer? and how? Of course, I mean a new installation on hard disk. thanks
girolez Often Off Piste Sep 23, 2014 #2 Hi It may be possible, but not straightforward. It also depends what your "pc" is. Suggest you start by looking here: Android-x86 - Porting Android to x86 Roger
kate Dreaming of Bugdroid Moderator VIP Member Sep 23, 2014 #3 I tested Android-x86 awhile ago and it actually worked, however it could be buggy depending on your computers hardware. Definitely worth a try though
jefboyardee Extreme Android User Sep 23, 2014 #4 There's always BlueStacks for running droid apps in your PC... I haven't tried it but hear good things about it.
