Help Android OS
Okay so im having problems with my Android OS draining huge amouts of mb's from my internet last month it used up in total like 2,2 gig and in 1 day now it used 331 mb and i do now know any possible way to fix this pleas help me.
With 6.0.1 you should be able to go into app permissions and remove data usage rights. Unfortunately Android OS covers a broad range of applications. Did you receive the Over-the-Air 6.0.1 update in the time since acquiring your S6? If not connected to WiFi some carriers will push that update with the data connection.
