Android phone specification for downloading and testing
texbala
hi there... I am looking for an Android phone - to download and test the apps that we will be creating.
Please suggest the phone specification, like how many MB free should be needed for downloading, browsing, testing maps etc...
advanced thnx... :)
from india...
I think Google Nexus S phone is the best for testing, because it is not messed with manufacturer UIs.
can we use a simple phone for testing also? say, Micromax X235 - which has an (Internal Memory 294 kb).
Please explain about the minimum requirment. :)
thnx,
Depends on the application you are developing.
For example, if it is using Adobe Air, then you will need minimum a phone with a Cortex-A8 CPU.
