android phone wont charge after it died
  • Start date Start date
A
Android Question
Guest
my phone won't charge after it died. the screen is cracked but not severely. i tried master rebooting it. it worked the first time but it wont work again. please help
There a few possibilities, none of which will really help you. Most likely, the motherboard cracked, or something on it broke off. Aside from replacing the screen, you'll probably have to replace the motherboard, and adding all the parts and labor will probably be more than the cost of a new phone.
