Android phone won't charge on laptop
Cinque8
Hello,
I have an Android 11 cell phone and a Dell Inspiron 3520 laptop computer..
For a few years, I would charge my cell phone, using a USB cable, on my laptop. But for some reason, my cell phone will not charge on my laptop anymore. I have tried using different laptop ports. But my phone still charges using a portable charger or a wall socket.
Has anyone else had this problem?
Thank you.
Charger, or clean out the USB ports using the system cleaner on windows ten, I have a few things that could help you out, Disk Clean up on your OS, also try to see if your phone is healthy for a clustering app that can disable it.
Hello Richard,
Thank you for your response. I am tapping on Build number, but nothing is happening. In the past, I have tapped on Build number, and Developer options and USB Debugging have come up.
Hi Richard,
Just to give an update. I did eventually get USB debugging up and running, but that didn't solve the problem. I tried everything from using different ports, using different cables. I cleaned the port on my phone with a toothpick and compressed air, but nothing fixed the problem. I did have a repair warranty on my phone with T-mobile, so I took the phone back to them to see if they could repair it. But they just gave me an identical pre-owned phone. Well, this phone works perfectly, and charges on my laptop. So now I am wondering if the way that I disconnected the phone from my laptop was the reason that the port failed?
