Help Android pin issue
michal8
My sim card is pin protected - it's not possible to disable this pin - I tried also contacting my operator. Is there any app able to enter this pin automatically when I restart phone, close airplane mode, so I will not see this annying pop up every time?
Hi
Normally in your phone it is possible to disable the sim pin;
menu
settings
security
sim card lock
allows you to change (or have no) sim card lock code.
Yes - I tried that - honestly on a few phones - unfortunately this sim card is blocked agains it. I have to enter the pin every time.
