Hi,
I having trouble with my phone yet again!!
Just disconnected it from the computer and it started heating up alot.
It then locked up completly.
I tried a forced battery removal and when it restarted it wasnt working properly and i got a Error report saying that android.process.acore was not responding.
Its running really sluggish - takes 5 to 10 seconds just to load the home screen when i unlock it.
non of the apps are running properly and for some odd reason the weather clock widget that ive got on the home screen keeps showing a different time than the clock on the menu bar.
Any help welcome cause i really love the phone but if this is another issue where i have to send if back again then im really starting to piss me off
Am I wrong in assuming that if the fix didn't work then there is a software fault?? I also checked to see if the HTC sytem would update it said there was no more updates that I needed.. After reading several forums, am I right to assume that said phone is beyond repair, and totally unfixable??
