Help android.process.media error
Blisk1
After I have update my phone samsung galaxy S to android ver 2.2 I constantly get this error android.process.media error.
Is there anybody which have the same problems, is there a solution?
I did read all of the posts for this error and I try all and nothing works.
I will try with another SD card if still happends I will change back to 2.1
I found out what is problem. In android ver 2.2 our language makes problems. When it is set to English it works ok. I have problems with download from Android Market too. It doesn't work no mather what I do. After setting english language all works ok.
Blisk,
Thank you, you are a life safer !
I spent the last month with almost unusable Galaxy S due to this problem and the fix is as you mentioned, only 10 seconds to get Market downloads working and no more android.process.media problems ... for now :-)
This is a really nasty bug and almost caused me to ditch my handset... !! is Samsung responsible for fixing this problem or is it an Android 2.1 system bug ?
