Hi,
I read about the Android RAM Management a lot, and I know that theoretically unused RAM is wasted RAM and that Android pre load common used application to the memory in order to optimize its perormance.
On the other hand, when ever I start filling that phone is has performance symptoms such as 'slow keyboard loading' or 'long time from the time I press the home key till it actually show the desktop', I just know that the used RAM is around 720 out of existing 830 and that I should close all open application (some times it is only one or two background applications).
Is it normal?
What can I do in order to optimize the performance?
Thanks
Yaron
Is it normal?
Thanks
Yaron
