Root Android Revolution HD whit problems
Fluturas
i just root my phone and put the Android Revolution HD 7.0.4 and I realized that I have some problems whit nativ mail from htc , i put mai mail and password and It say are not good, they are checked, and a nother problem i have whit facebook who does not want start and is show this msg " sorry! The application facebook( process com.facebook.katana) has stopped unexpectedly. please try again" whoat can i go ???
how did you install the rom?
the correct procedure would be basically:
-boot to recovery
-wipe data/factory reset
-wipe cache
-wipe dalvik cache
-flash rom
-reboot
if you didnt do those wipes,you might try re-installing your rom.
also,make sure that you did NOT use titanium backup,or my backup pro to install anything other than user apps.
awsome,glad to hear it. it would be nice if he would show back up and describe his solution,since we offered him help here.
I am not sure he is coming back. Just decided to post what the result was, in case someone else with this problem sees this post.
You did give him the correct solution, with a clear step by step on the order one should wipe.
