Help Android S3 stuck in headset mode
Love this phone. Only had it a couple of days but last night I unplugged the headset and the icon went away but I get now sound on the phone. I can still make calls but no ringer or any other of the animated sounds on the phone. I have rebooted, taken the batter out, put the jack in and out, even reset to factory, with still not joy. Any help would be greatly appreciated.
Don McDaniel
Hello donmcdaniel and welcome to Android Forums. :)
Have you gone into your settings and checked if the sounds was turned down by any chance?
You won't believe it. After jumping through hoops all day I accidentally dropped it off my desk onto the rug and the sound came back. Very strange.
Thanks for the reply.
donmcdaniel
I wouldn't rely on that solution if I were you, I'd consider taking it in and getting it swapped.
I agree, sometimes its a fault with the connectors inside the headset socket that let the phone think there's still something in there.
Always worth taking it in and swapping it to avoid the overall headache it will cause in the future if you are a regular headphone user.
