Android SDK ADT bundle. Please help.
I have just downloaded the Android SDK ADT bundle that is supposed to contain everything that I need to start making apps. The problem that I am having is this. When I go to open Eclipse I gen an error message that says
"The version of this file is not compatible with the version of Windows you are running. Check your computer's system information to see whether you an x86 (32-bit) or x64 (64-bit) version of the program and then contact the software publisher."
Now I did check the system requirements for the ADT bundle and it was plainly put that I could run it on a 32 or 64 bit system and the bundle should work fine. I'm sure that I overlooked something and I just need to know what it is. Any info will be appreciated.
