Android Sdk Installation on Macbook
kevlangdo
I recently started developing Android apps using Eclipse on a Macbook, however I discovered errors (bugs) in the installation package of the Android SDK. After a few hours work I figured the issues and worked out a solution. I am posting the solution here in case anyone may have run into the same problems
Android | How-To Install Android SDK in Eclipse on a MacBook Pro
http://klanguedoc.hubpages.com/hub/H...DK-MacBook-Pro
