Android SDK installation problem
Hi,
I am using Eclipse and had downloaded all necessary updates. Unfortunately, I am unable to create a new project.
Under the New>Projects option I am unable to select New Android Project. It is missing from the list (please refer to the print screen).
I am not sure if I correctly installed the Android SDK. Or I missed out some steps during the installation.
I'm new to Android so I would appreciate it if someone could help me on this matter. Thanks a lot in advance. :)
Thanks a lot. I actually missed the step to install the Android ADT. Initially I thought the Android ADT is included as part of the Eclipse (Galilieo) package.
Yay, now looking forward to do some programming. :D
