android sdk location should not contain whitespaces
werner111
Hi,
For my unity project I need a higher sdk. When I want to change it in android studio (settings -> andriod SDK) I get the message:
"android sdk location should not contain whitespaces"
The location is: "Program files" with whitespaces
C:\Program Files\Unity\Hub\Editor\2021.3.24f1\Editor\Data\PlaybackEngines\AndroidPlayer\SDK
What I try:
- I can't rename the map because it cause a lot of issues
- I fill: c:\progra~1\Unity\Hub\Editor\2021.3.24f1\Editor\Data\PlaybackEngines\AndroidPlayer\SDK
but it doesn't work, I cant select this directory
In android studio I have android api 33 at the directory:
C:\Users\werne\AppData\Local\Android\Sdk
It doesn't work when I fill this location in Unity.
Anyone a idea?
One solution could be to create a symbolic link for the Android SDK directory. This will create a shortcut to the actual directory without any whitespaces in the path. Here are the steps to create a symbolic link: 1. Open a command prompt in administrator mode 2. Navigate to the directory where you want to create the symbolic link (e.g. C:\Program Files\Unity\Hub\Editor\2021.3.24f1\Editor\Data\PlaybackEngines\AndroidPlayer) 3. Type the command: mklink /D AndroidSDK "C:\Program Files\Unity\Hub\Editor\2021.3.24f1\Editor\Data\PlaybackEngines\AndroidPlayer\SDK" 4. This will create a symbolic link named "AndroidSDK" that points to the actual Android SDK directory without any whitespaces in the path 5. Now you can use the location "C:\Program Files\Unity\Hub\Editor\2021.3.24f1\Editor\Data\PlaybackEngines\AndroidPlayer\AndroidSDK" in Unity to select the Android SDK directory. Note: Make sure to replace the actual path of the Android SDK directory in step 3 with the correct path on your system.
Thanks you for your steps, I try it but it didn't work.
1. Do I need to use in step 3 this path:
or
Because I want to change the SDK
2. Do I need to type this without whitespraces in "Program files" in step 3?
Like this:
C:\ProgramFiles\Unity\Hub\Editor\2021.3.24f1\Editor\Data\PlaybackEngines\AndroidPlayer\SDK
