Hi,
I'm hoping someone here can help me, I am trying to create a basic application that transmits GPS co ordinates of the device to a server. I am a complete noobie to socket programming (well, I covered the bare basics in college this year).
As a stepping stone, I am following a tutorial, that creates the server, and the android client, it is designed to send an input from the user to the server and the server prints it on the console.
I'm becoming quite familar with how to set up the basics of the server and the client i.e. opening ports etc. The problem with this is, when hit send, the app crashes, when tested on the emulator, there is obviously an issue, but I can't see it.
When I test with device, and hit send, there is nothing printed to the console. I've attached both the client and server code below, the ip in the code below is for the emulator, I change this to my device ip with testing with it.
****SERVER****
[HIGH]
public class Additional_Server {
private static ServerSocket serverSocket;
private static Socket clientSocket;
private static InputStreamReader inputStreamReader;
private static BufferedReader bufferedReader;
private static String message;
public static void main(String[] args) {
try {
serverSocket = new ServerSocket(2001); // Server socket
} catch (IOException e) {
System.out.println("Could not listen on port: 2001");
System.out.println("Server started. Listening to the port 2001");
while (true) {
try {
clientSocket = serverSocket.accept(); // accept the client connection
inputStreamReader = new InputStreamReader(
clientSocket.getInputStream());
bufferedReader = new BufferedReader(inputStreamReader); // get the client message
message = bufferedReader.readLine();
System.out.println(message);
inputStreamReader.close();
clientSocket.close();
} catch (IOException ex) {
System.out.println("Problem in message reading");
[/HIGH]
****CLIENT****
[HIGH]
import android.os.Bundle;
import android.app.Activity;
import java.io.IOException;
import java.io.PrintWriter;
import java.net.Socket;
import java.net.UnknownHostException;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
public class TCPclient extends Activity {
private Socket client;
private PrintWriter printwriter;
private EditText textField;
private Button button;
private String messsage;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.activity_tcpclient);
textField = (EditText) findViewById(R.id.Msg); // reference to the text field
button = (Button) findViewById(R.id.bSend); // reference to the send button
// Button press event listener
button.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
messsage = textField.getText().toString(); // get the text message on the text field
textField.setText(""); // Reset the text field to blank
try {
client = new Socket("127.0.0.1", 2001); // connect to server
printwriter = new PrintWriter(client.getOutputStream(),
true);
printwriter.write(messsage); // write the message to output stream
printwriter.flush();
printwriter.close();
client.close(); // closing the connection
} catch (UnknownHostException e) {
e.printStackTrace();
[/HIGH]
I really would appreciate any help, I'm pulling my hair out here. Any specifics would be great. Thanks in advance!!!
****SERVER****
[HIGH]
try {
while (true) {
try {
[/HIGH]
****CLIENT****
[HIGH]
@Override
try {
true);
[/HIGH]
utputStream;
