Help Android Settings
  • Start date Start date
A
Android Question
Guest
Hi to all. I have the following problem in my ZTE Blade L3 plus phone. I open the incognito window and access my gmail account. After 2-3 minutes of idle i try to refresh the account and it says disconnected ie it does not refresh. If i switch the data off and on again i have to logon to account from the beginning (go to page type credentials etc). I remember that some days ago the situation was that even in incognito mode i could refresh the page and retrieve my emails from the server without this tedious procedure. In the mean time i have also installed Bit defender in my device. Can you please help me retain the gmail account logon after switching the data off?
incognito didn't save cookies.
what you are currently experiencing is correct. ish. (it should forget your login info as soon as you navigate away from gmail, but not from just a refresh of current page)
I suspect bitdefender is invalidating the cookies sooner. try using the refresh button in gmail, not the refresh control button for your browser.
if it still operates the same way, it is a bug.
