I am running into an annoying behavior with the soft keyboard I have not experienced before with Android. With the physical keyboard on the Samsung Intercept I prefer to turn off the soft keyboard in the preferences but it turns itself back on if the keyboard is not open and I select an input area. I would like to uninstall the soft keyboard all together since I will not use it. Is there a way to do this with the stock rom?
Thanks in advance for any responses.
