Apps Android Studio Auto Indent (Without Ctrl+Alt+L)
Javez
Hi, I was wondering if there's an option in Android Studio that automatically indents every line, without the need of having to press Ctrl+Alt+L each time?
Where, when you click the whitespace, it automatically knows and places your cursor at the appropiate position, without the need to press Enter from the previous line (or use Ctrl+Alt+L)?
I believe Eclipse works that way, but not Android Studio, which leads to a lot of excessive key presses. I don't like having to rely on an auto format everything hotkey, as it automatically formats certain blocks I don't wish to format.
Thanks in advance!
