Kamel Hamdan
Here's the code for "connect to TANGO" button
Java:
import android.app.Activity;
import android.bluetooth.BluetoothAdapter;
import android.bluetooth.BluetoothDevice;
import java.util.UUID;
import android.bluetooth.BluetoothServerSocket;
import android.bluetooth.BluetoothSocket;
import android.content.Intent;
import android.os.Bundle;
import android.support.v7.app.AppCompatActivity;
import android.view.View;
import android.widget.ArrayAdapter;
import android.widget.Button;
import android.widget.ListView;
import android.widget.Toast;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Set;
public class connection extends AppCompatActivity {
Button b1,b2,b3,b4;
private BluetoothAdapter BA;
private Set<BluetoothDevice>pairedDevices;
ListView lv;
@Override
setContentView(R.layout.activity_connection);
b1=(Button)findViewById(R.id.button);
b2=(Button)findViewById(R.id.button2);
b3=(Button)findViewById(R.id.button3);
b4=(Button)findViewById(R.id.button4);
BA = BluetoothAdapter.getDefaultAdapter();
lv = (ListView)findViewById(R.id.listView);
public void on(View v){
if (!BA.isEnabled()) {
Intent turnOn = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
startActivityForResult(turnOn, 0);
Toast.makeText(getApplicationContext(), "Turned on",Toast.LENGTH_LONG).show();
} else {
Toast.makeText(getApplicationContext(), "Already on", Toast.LENGTH_LONG).show();
public void off(View v){
if (BA.disable());
Toast.makeText(getApplicationContext(), "Turned off" ,Toast.LENGTH_LONG).show();
public void visible(View v){
Intent getVisible = new Intent(BluetoothAdapter.ACTION_REQUEST_DISCOVERABLE);
startActivityForResult(getVisible, 0);
public void list(View v){
pairedDevices = BA.getBondedDevices();
ArrayList list = new ArrayList();
for(BluetoothDevice bt : pairedDevices) list.add(bt.getName());
Toast.makeText(getApplicationContext(), "Showing Paired Devices",Toast.LENGTH_SHORT).show();
final ArrayAdapter adapter = new ArrayAdapter(this,android.R.layout.simple_list_item_1, list);
lv.setAdapter(adapter);
public class RandomStringUUID {
public void main(String[] args) {
// Creating a random UUID (Universally unique identifier).
UUID uuid = UUID.randomUUID();
String randomUUIDString = uuid.toString();
System.out.println("Random UUID String = " + randomUUIDString);
System.out.println("UUID version = " + uuid.version());
System.out.println("UUID variant = " + uuid.variant());
private final BluetoothSocket mmSocket;
private final BluetoothDevice mmDevice;
public connection(BluetoothDevice device) {
// Use a temporary object that is later assigned to mmSocket,
// because mmSocket is final
BluetoothSocket tmp = null;
mmDevice = device;
// Get a BluetoothSocket to connect with the given BluetoothDevice
try {
// MY_UUID is the app's UUID string, also used by the server code
tmp = device.createRfcommSocketToServiceRecord(UUID.randomUUID());
} catch (IOException e) { }
mmSocket = tmp;
public void run() {
// Cancel discovery because it will slow down the connection
BA.cancelDiscovery();
try {
// Connect the device through the socket. This will block
// until it succeeds or throws an exception
mmSocket.connect();
} catch (IOException connectException) {
// Unable to connect; close the socket and get out
try {
mmSocket.close();
} catch (IOException closeException) { }
return;
// Do work to manage the connection (in a separate thread)
manageConnectedSocket(mmSocket);
private void manageConnectedSocket(BluetoothSocket mmSocket) {
/** Will cancel an in-progress connection, and close the socket */
public void cancel() {
try {
mmSocket.close();
public BluetoothDevice getMmDevice() {
return mmDevice;
And that's the code for the "Translate" button
Java:
import android.os.Handler;
import android.os.Message;
import java.io.InputStream;
import java.io.OutputStream;
public class display extends AppCompatActivity {
@Override
setContentView(R.layout.activity_display);
private final InputStream mmInStream;
private final OutputStream mmOutStream;
private android.os.Handler mHandler;
public display (BluetoothSocket socket, Handler mHandler) {
mmSocket = socket;
this.mHandler = mHandler;
InputStream tmpIn = null;
OutputStream tmpOut = null;
// Get the input and output streams, using temp objects because
// member streams are final
try {
tmpIn = socket.getInputStream();
tmpOut = socket.getOutputStream();
mmInStream = tmpIn;
mmOutStream = tmpOut;
public void run() {
byte[] buffer = new byte[1024]; // buffer store for the stream
int bytes; // bytes returned from read()
// Keep listening to the InputStream until an exception occurs
while (true) {
try {
// Read from the InputStream
bytes = mmInStream.read(buffer);
// Send the obtained bytes to the UI activity
int MESSAGE_READ = 0;
mHandler.obtainMessage(MESSAGE_READ, bytes, -1, buffer)
.sendToTarget();
break;
/* Call this from the main activity to send data to the remote device */
public void write(byte[] bytes) {
try {
mmOutStream.write(bytes);
/* Call this from the main activity to shutdown the connection */
try {
mmSocket.close();
