Hi, i am new in Android dev, and i need some help with my Android Studio.
I am trying to import some libraries, in Android Studio. I had the following error message: Error:The SDK Build Tools revision (17.0.0) is too low for project ':actionbarsherlock'. Minimum required is 19.1.0
So i installed Android SDK Build tools rev 19.1.0. I modified build.gradle file (app) looking like this:
apply plugin:'com.android.application'
android {
compileSdkVersion 19
buildToolsVersion '19.1.0'
defaultConfig {
applicationId "com.example.xx.xx"
minSdkVersion 16
targetSdkVersion 19
versionCode 1
versionName "1.2"}
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'),'proguard-rules.pro'}}}
dependencies {
compile fileTree(dir:'libs', include:['*.jar'])
compile 'com.android.support:appcompat-v7:19.1.0'
compile 'com.android.support:support-v4:19.1.0'
compile project(':actionbarsherlock')
compile project(':actionbarsherlock-fest')
compile project(':actionbarsherlock-i18n')}
Also in Run/Debug Configurations, under App Engine DevAppServer, i set in App Engine SDK field the path for the new SDK, looks like that: C:\Users\xxxx\AppData\Local\Android\sdk\build-tools\19.1.0
So when i am trying to rebuild, i get exactly the same error message as before. Additionally, i had installed Android SDK Build tools rev 22.0.1, and i get warning saying update targetSdkVersion to 22.
Did anyone else have this problem before?
Thank you
android {
defaultConfig {
minSdkVersion 16
targetSdkVersion 19
versionCode 1
versionName "1.2"}
buildTypes {
release {
minifyEnabled false
dependencies {
Thank you
