(Android studios) How to connect 2 arduino to android app
Hello,
I have tried many ways to make the connection of 2 Arduino to an App but I still can't get it to run smoothly. Is there any experts out there that can help me out? I just want to connect one Arduino for 5 seconds and disconnects and then connect to the other Arduino continuously. My code is working but it sometimes doesn't connect at all or where after 5 seconds, the first Arduino BT disconnects and the other Arduino doesn't get connected. Or both the Arduino starts connecting once the App starts.
Much help appreciated!!
Thank you!
Here is my code:
Java:
<pre>package com.busapp.simple.lcdlightsensor;
import android.bluetooth.BluetoothAdapter;
import android.bluetooth.BluetoothDevice;
import android.bluetooth.BluetoothSocket;
import android.content.Intent;
import android.os.CountDownTimer;
import android.os.Handler;
import android.os.Message;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.util.Log;
import android.widget.TextView;
import android.widget.Toast;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.Set;
import java.util.UUID;
public class MainActivity extends AppCompatActivity {
    private static final String TAG = "ArduinoBT";
    //Light
    private static final String BT_NAME = "RNBT-E341";
    String incomingMsg;
    TextView lightConn;
    BluetoothAdapter mBluetoothAdapter;
    BluetoothDevice mDevice;
    Set<BluetoothDevice> pairedDevices;
    ConnectThread mConnectThread;
    ConnectedThread mConnectedThread;
    //LCD
    TextView lcdConn;
    private static final String BT_NAME_LCD = "RNBT-E34E";
    BluetoothAdapter BluetoothAdapterforLCD;
    BluetoothDevice DeviceforLCD;
    Set<BluetoothDevice> pairedDevicesforLCD;
    ConnectThread_LCD ConnectThreadforLCD;
    ConnectedThread_LCD ConnectedThreadforLCD;
    @Override
        setContentView(R.layout.activity_main);
        mBluetoothAdapter = BluetoothAdapter.getDefaultAdapter();
        BluetoothAdapterforLCD = BluetoothAdapter.getDefaultAdapter();
        if (!mBluetoothAdapter.isEnabled()) {
            Intent enableBtIntent = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
            startActivityForResult(enableBtIntent, 1);
        pairedDevicesforLCD = BluetoothAdapterforLCD.getBondedDevices();
        if (pairedDevicesforLCD.size() > 0) {
            for (BluetoothDevice device : pairedDevicesforLCD) {
                if (device.getName().equals(BT_NAME_LCD)) {
                    DeviceforLCD = device;
        pairedDevices = mBluetoothAdapter.getBondedDevices();
        if (pairedDevices.size() > 0) {
            for (BluetoothDevice device : pairedDevices) {
                if (device.getName().equals(BT_NAME)) {
                    mDevice = device;
        Toast.makeText(
                this,
                "" + DeviceforLCD.getName() + " & " + mDevice.getName(),
                Toast.LENGTH_LONG).show();
        CountDownTimer countDownTimer = new CountDownTimer(10000, 1000) {
            @Override
            public void onTick(long millisUntilFinished) {
//                ConnectThreadforLCD = new ConnectThread_LCD(DeviceforLCD);
//                ConnectThreadforLCD.start();
                Log.i(TAG, "Countdown start");
            @Override
            public void onFinish() {
                if ((ConnectedThreadforLCD != null) && (ConnectThreadforLCD != null)) {
                    ConnectThreadforLCD.cancel();
                    ConnectedThreadforLCD.cancel();
                    Log.i(TAG, "LCD Cancelled");
        countDownTimer.start();
//        mConnectThread = new ConnectThread(mDevice);
//        mConnectThread.start();
//        Log.i(TAG, "Connect to device: " + mDevice.getName());
    public class ConnectThread_LCD extends Thread {
        private BluetoothSocket lcdSocket;
        private BluetoothDevice lcdDevice;
        private UUID MY_UUID = UUID.fromString("00001101-0000-1000-8000-00805f9b34fb");
        public ConnectThread_LCD(BluetoothDevice device) {
            BluetoothSocket tmp = null;
            lcdDevice = device;
            if (tmp == null) {
                try {
                    tmp = device.createRfcommSocketToServiceRecord(MY_UUID);
                } catch (IOException e) {
            else {
                lcdSocket = tmp;
//            try {
//                tmp = device.createRfcommSocketToServiceRecord(MY_UUID);
//            } catch (IOException e) { }
            lcdSocket = tmp;
        public void run() {
            Log.i(TAG, "LCD Discover");
            if (BluetoothAdapterforLCD.isDiscovering()) {
                BluetoothAdapterforLCD.cancelDiscovery();
            try {
                Log.i(TAG, "LCD Connected");
                lcdSocket.connect();
            } catch (IOException connectException) {
                try {
                    lcdSocket.close();
                    Log.i(TAG, "LCD Socket Closed");
                } catch (IOException closeException) { }
                return;
            Log.i(TAG, "LCD ConnectedThread start");
            ConnectedThreadforLCD = new ConnectedThread_LCD(lcdSocket);
            ConnectedThreadforLCD.start();
        public void cancel() {
            try {
                if (lcdSocket.isConnected()) {
                    lcdSocket.close();
                    lcdSocket = null;
    public class ConnectedThread_LCD extends Thread {
        private InputStream lcdInstream;
        private OutputStream lcdOutstream;
        public ConnectedThread_LCD(BluetoothSocket socket) {
            Log.i(TAG, "Connected Thread");
            lcdSocket = socket;
            InputStream tmpIn = null;
            OutputStream tmpOut = null;
            try {
                tmpIn = lcdSocket.getInputStream();
                tmpOut = lcdSocket.getOutputStream();
                e.printStackTrace();
            lcdInstream = tmpIn;
            lcdOutstream = tmpOut;
            write(1);
            lcdHandler.obtainMessage(0, 0).sendToTarget();
            Log.i(TAG, "InputStream contains tmpIn");
        public void run() {
            byte[] buffer = new byte[2048];
            int bytes;
            try {
                    lcdInstream.close();
                    lcdOutstream.close();
                    lcdSocket.close();
                    lcdSocket = null;
        public void write (int bytes) {
            try {
                lcdOutstream.write(bytes);
    Handler lcdHandler = new Handler() {
        String s;
        @Override
        public void handleMessage(Message msg) {
            switch (msg.what) {
                case 0:
//                    ConnectThreadforLCD.cancel();
//                    ConnectedThreadforLCD.cancel();
                    Log.i(TAG, "LCD BT Cancelled");
                    break;
    //Arduino Code
    public class ConnectThread extends Thread {
        private BluetoothSocket mmSocket;
        private BluetoothDevice mmDevice;
        public ConnectThread(BluetoothDevice device) {
            mmDevice = device;
            if (tmp == null) {
                try {
            else {
                mmSocket = tmp;
//            try {
            mmSocket = tmp;
        public void run() {
            if (mBluetoothAdapter.isDiscovering()) {
                mBluetoothAdapter.cancelDiscovery();
            Log.i(TAG, "Discovering");
            try {
                mmSocket.connect();
                Log.i(TAG, "Socket Connected");
                try {
                    mmSocket.close();
                return;
            mConnectedThread = new ConnectedThread(mmSocket);
            mConnectedThread.start();
            Log.i(TAG, "Connect Started");
            try {
                if (mmSocket.isConnected()) {
                    mmSocket.close();
                    mmSocket = null;
    public class ConnectedThread extends Thread {
        private InputStream mmInstream;
        private OutputStream mmOutstream;
        public ConnectedThread(BluetoothSocket socket) {
            mmSocket = socket;
            try {
                Log.i(TAG, "(aaa6)");
                tmpIn = mmSocket.getInputStream();
                tmpOut = mmSocket.getOutputStream();
            Log.i(TAG, "(aaa7)");
            mmInstream = tmpIn;
            mmOutstream = tmpOut;
            write(1);
        public void run() {
            //String incomingMsg;
            int bytes;
            while (true) {
                Log.i(TAG, "While true");
                try {
                    bytes = mmInstream.read(buffer);
                    //Log.i(TAG, "Buffer read" + String.valueOf(bytes));
                    byte[] buff = new byte[bytes];
                    Log.i(TAG, "Buffer read" + bytes);
                    System.arraycopy(buffer, 0, buff, 0, bytes);
                    incomingMsg = new String(buff);
                    if(incomingMsg.equals(" "))
                        continue;
                    Log.i(TAG, "(aaa11)");
                    mHandler.obtainMessage(1, incomingMsg).sendToTarget();
                    Log.i(TAG, "InputStream " + incomingMsg);
                    Log.i(TAG, "Error reading input " + e.getMessage());
            try {
                    mmInstream.close();
                    mmOutstream.close();
                    mmSocket.close();
                    mmSocket = null;
            try {
                mmOutstream.write(bytes);
    Handler mHandler = new Handler() {
        String s;
        @Override
            switch(msg.what) {
//                case 0:
////                    ConnectThreadforLCD.cancel();
////                    ConnectedThreadforLCD.cancel();
//                    aConnectThread = new ConnectThread(aDevice);
//                    aConnectThread.start();
//                    Log.i(TAG, "LCD BT Cancelled");
//                    break;
                case 1:
                    Log.i(TAG, "Message handled");
                    s = (String) incomingMsg;
                    if (s!=null) {
//                        lightValue.setText(s);
//                        if ((Integer.parseInt(s) <= 300) || (Integer.parseInt(s) >= 500)) {
//                            sendRequest(lightOn);
//                            Log.i(TAG, "Send IFTTT request");
//                        else {
//                            sendRequest(lightOff);
                    break;
    @Override
    protected void onDestroy() {
        super.onDestroy();
        mConnectThread.cancel();
        mConnectedThread.cancel();
If you're using Bluetooth to connect with both, I don't know how you get past that problem. But looking through some postings on the Arduino forum if you have a USB OTG adapter this should allow you to have one on BT and the other connects over USB.
Your app needs to be interactively debugged, which is virtually impossible to do on an internet forum. What you should do, is run the app in debug mode, and set breakpoints at crucial places, to determine what's going on. Multithreaded code is, by nature more difficult to debug, as things are happening in parallel, and pausing execution of a thread can cause timing issues.
If you have a more focused question, you can ask it here, but as it stands your question as phrased is very difficult to answer.
Alright I will do that :) Thank you for replying
Alright I will try that too!! Thank you for replying!!
UPDATE: I still can't find the issue. Tried debugging, it shows me the device mac address that is found but it doesn't connect but sometimes it does.
