Today, my android phone changed its own security code PIN out of nowhere.
I got no clue as to what happened since I didnt intentionally/manually change it.
I was using the phone when it got abruptly changed, this is what I did;
- Simply replaced my SIM card with a newly delivered one from my carrier.
I logged in just fine with my own, usual Security Code.
As I put it in SIM tray 2 initially, my phone booted up but didnt indicate SIM card presence so I went to ''SIM cards'' in Settings menu. Once there, my phone locked up to ask me for the Security code (NOT simcard pin though) I was already wondering why the sudden re-prompt as I was already in Android, but from nowhere my own, old Security privacy code didnt work anymore!
So I dont know if being in the SIM card menu has anything to do with it. After putting it into SIM slot 1 it didn't solve, and even putting back my old SIMcard didnt solve it.
It seems I am now stuck with an security code that I do not even know!
Some unknown event changed it. But it must be very coincidental if SIMcard replacement has nothing to do with it. Never seen Android change my own security code before.. until today.
Note that my SIM PIN and Security Android privacy code isnt something I am mixing up; the PIN is still 0000 and lets me past the first lockscreen (PIN) fine until it doesnt take my Security code anymore on that respective lockscreen. Very weird
I dont want to need resetting my phone, i think this is a bug but maybe someone knows a solution? (NOTE: The phone is a Doogee F5 with Android 5.1
