Help Android System Recovery Problem
Claudiu122
I have a problem with the Android System Recovery.When i press "reboot system now"it's like bringing me back to the "Death Android Screen".Could you please help me with this????? DEVICE:Lenovo a2010
That is recovery. So if an ordinary boot is taking you into recovery that suggests that your ROM is messed up.
Can you tell us how you got into this state (e.g. why you were in recovery in the first place, or what happened before this started)?
I update it and i think it failed. I don't know maybe that's the problem.Afther that it showed me the Death Android screen
If an update failed (i.e. the system tried to apply a corrupt update file, or was interrupted while flashing the update) that could certainly cause this.
In that case you only have a few options. If it was a problem with user apps or corrupt settings a factory reset would fix it, but from what you've said that sounds unlikely to work. If it's a broken update then the only option is to reflash the system software. I don't know how one does that with a Lenovo, but hopefully someone will be able to suggest something. Otherwise if have any sort of Lenovo service then they can fix it (and really ought to do so for free if their update borked it).
