Android Tablets problem
Haq
Hi !!
Recently I've bought a china tablet. It was working good, but unfortunately I had done something wrong & now the tablet creates too many problems, such as ...
1. It won't display all the font labels. eg: not showing the labels of settings, camera etc in the menu.
attachment.php
2. When I try to install any apk file, most of the texts are black, so I can't even choose ok or cancel button, but the button highlight instead.
3. In the Settings menu, icons are ok but without any texts.
attachment.php
4. When I press the turn off button, the menu appears without any text but buttons.
attachment.php
What should I do? Some installed games run ok with full texts......... So I guess this is not the problem of display rather the operating system.......... Any help from the experts??
OS: Android 4.0.4
Ram: 512 MB
Model: L29i
M1190_V1.09_P10
ubuntu-L29iA-20130411
When you say you did something wrong? What did you do before that started happening?
Have you tried rebooting?
What about a factory reset?
I also suggest a reboot and if that doesn't help try a factory reset. But if it's still acting funky after that you'll probably have to RMA it as faulty.
At last I found a solution...:). Thanks to El Presidente & mikedt. A factory reset has solved my problem...Thank u ...:D
