My PC is connected to the LAN through proxy. I have set the proxy in emulator too. But when I am trying to use HttpURLConnection, the app crashes and the log says "Thread exiting with uncaught exception" .
Please have a look at my Code. The activity creates a button and textview. On clicking the button it starts an async task which fetches the contents of a URL using HttpURLConnection and updates the textview with the response code.
Where am I doing wrong? One more question: Am I setting the proxy in the correct way?
When I remove the line "int response = httpURLConnection.getResponseCode();" the app works. But if I add it the app crashes.
Any help will be highly appreciated.
Regards!
Code:
public class GWRSSReader extends Activity {
TextView tv;
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
Button button=(Button)findViewById(R.id.button1);
tv=(TextView)findViewById(R.id.textView1);
button.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
DownloadWebPageTask task = new DownloadWebPageTask();
task.execute();
private class DownloadWebPageTask extends AsyncTask<Void, Void, String> {
@Override
protected String doInBackground(Void...voids) {
String code="";
try{
SocketAddress sa=new InetSocketAddress("ps1.iiit-bh.ac.in",8080);
Proxy p=new Proxy(Proxy.Type.HTTP,sa);
URL url = new URL("http://google.com");
HttpURLConnection httpURLConnection = (HttpURLConnection)url.openConnection(p);
int response = httpURLConnection.getResponseCode(); // this line crashes the app
code=String.valueOf(response);
catch(Exception e){Toast.makeText(getApplicationContext(), "error", Toast.LENGTH_LONG);}
return code;
@Override
protected void onPostExecute(String result) {
tv.setText(result);
Regards!
