Android to Android Remote Control
Can someone help and advise where I may locaate product etc that will do:
Android A is to send messages to Android B which is hooked up to two r/c type servos to control speed direction in a vehicle. Do not want bluetooth as this is limited to 100m I want to use of 2 km.
Essentially a bluetooth r/c car controller (plenty available) but a long distance versiopn using the phone network.
Thanks
charlie
Hi Adunfong
Thanks for your response.
The both phones will be outdoors, no use of computer can be made.
I am new to this. What does the DTMF, is that a normal function of Android ?
Can your refer me to a site where this is being done .
Thankyou
Charlie
