android to protect from malware and malicius software
I have problem when charging my handphone and it indicated full but after using it not more than 10-15 minutes, the battery indicated that the batery is almost empty. and sometimes it turn off automatically. but when i turn the phone off and charging the battery, the battery indicator shows that the green is almost 90% full instead of empty.
at first i thought it was the battery of the phone caused the problem, but after format and reinstall the android 2.3 the problem solved.
but now after i installing same games and application from the android stores i am having again the same problem.
did anyone having the same problem as mine? what is the virus tat effecting my device ya?
the antivirus i used, lookout and bit diffender both does not indicate any virus or malware in my phone. whether before reformat and reinstall the android neither after format and reinstall the android OS.
please advice.
regards,
Ayu
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
Lookout is very good and you can get it from the Play store
