Root Android Tuner/3C Toolbox question?
CrimsonToker
Android Expert
Is there an online guide, or tutorial anywhere for using this? I just installed it, and the amount of things it can do is a bit overwhelming...
Also, on first opening it, I get this message. Not sure what it means. Can anyone explain? Thank you for any help!
Is your phone rooted?
It looks like your system partition doesn't have super user access or you would have gotten the prompt for root permission, at least thats what happened to me. I run tweaks at boot with it
Guys, it shows superuser access is granted in the screenshot.
I just installed this to look at it. Did you realize that it uses Xposed framework for some functions? When I first installed it, I got that error. Enabled in Xposed, rebooted, no more error.
Yeah, I enabled in Xposed and haven't seen that same message again. If anyone knows how to take it out of expert UI mode, that would be helpful. It told me how to when I put it in expert mode, but I can't figure it out now. I don't like it, and want to go back to default. I looked through settings but can't find it
Easiest way would be to clear data
Hi, after messing with system settings on 3C I can no longer access my memory card or primary device memory. All I'm seeing is 0 space available in all storages. Some apps have stopped working too. Apps on SD for the most part seem to work fine but the data on the SD card is not recognized at all. Please help. I have a rooted T-Mobile Galaxy S5.
You do realize that this is the LG Volt forum...there's not much we can do since your using a S5
Been using this since way back with my LG Optimus running Gingerbread. Was super kick ass back then. Now it's just too much. I use it mostly to set memory limits and (on other devices) CPU overclock settings. . Dont know if it's the Volt or the newer android/app versions, but doesn't seem to work as well with the volt as it did with my previous devices. The battery monitor used to be the best around but when 3c incorporated it into the system tuner, things got way too complicated to be user friendly. Anymore, Like most things that do everything, it doesn't do anything great.
