Android -unavaiable?
Tyla
Hey:) I'm using Tattoo and still discovering the phone(yeah, it's cool).
I'm a bit angry, because I bought this phone from service at an auction. Well, it didn't say the phone was imported from Germany... :mad:
Anyway each time I'm trying to "set up my Google account" it says "you don't have a network connection" while I can check my e-mail by just login-in'ng in normal Gmail.com site. "this could be a temporary problem or your SIM card may not be provisioned for data services".
I think there are cool thinks in Android Market and I would like to buy some applications...
Anyone else with something like that? Any ideas? If nothing I'll try with customer care...;)
I think you need to speak to your service provider. Sounds like the settings are wrong, or that you have an old SIM card.
- Mark
Oh well thanks to all of you. On days I'll contact with provider, we'll see if they can help. :)
Cheers
I had the same problem with my Tattoo, bought in Hong Kong.
After trying for several minutes, rebooting the device did the trick.
