Android updation
  • Start date Start date
A
Android Question
Guest
Is their any procedure to update android 2.2 without use of internet,via software?
Hi
How to update your android installation depends on which device you have. If you do not/cannot do an OTA update then you will need a PC + usb lead. The PC will need internet access to download the required files for installation. The files are specific to each device
I suggest that you register on the forums and post your question again in the forum for your particular device, giving as much information about it as you can.
Good luck
Roger
