Android USUSB not recognised - settings completely disappeared
Good day,
Yesterday I connected my Huawei P30 Pro with Android version 10 to my PC with Windows 10 via USB as usual. The computer did not recognise the device as a USB device. So I tried to change some settings in the device. When I then switched off the developer mode, I was no longer able to select any USB-related settings in the settings. The entries still appeared in the menu and in the menu-internal search, but could no longer be selected.
I then tried to solve the problem by resetting the network settings. Now all the USB-related entries no longer even appear in the system settings. When I plug it in, however, the "USB usage" dialogue appears and when I select "Enter MIDI", the computer recognises the device. However, data transfer is not possible in any of the modes.
I would like to avoid resetting the device completely, is there another possibility, maybe reinstalling the USB driver manually or similar?
Many thanks in advance for your help!
