i try to displaying value of my table in android, and i put my code into hosting, but when i try to running my app, my link doesn't work,
and i tried to create new link that displays the same output , and its works fine,
this is my code to encode json
did I'm doing something wrong?? because I want to set the output from the database
PHP:
<?php
include 'dbconfig.php';
$con = new mysqli($servername, $username, $password, $dbname);
if (mysqli_connect_errno()) {
echo "Failed to connect to MySQL: " . mysqli_connect_error();
$query = "select id,ask from pertanyaan";
$result = mysqli_query($con, $query);
while ($r = mysqli_fetch_array($result)) {
extract($r);
$rows[] = array(
"id"=>$id,
"ask"=>$ask
header('Content-Type: application/json');
echo json_encode($rows);
mysqli_close($con);
