Help Android wifi-direct api for support Multi-group Networks
xxxxx56789
My application need to create multi-group wifi-direct communication.But after testing I find that none of the following scenarios are feasible in Android:
1) a device plays the role of P2P client in one group and GO in another. 2) a device behaves as client in two or more groups.
I want to ask does the google have the plan to update the android Wifi-Direct API for suppporting one of above, so that we could implement multi-group communication easily?
Or are there some ways for two wifi-direct group communication with each other in android?
Thanks!!!!!!!!!!!!!!!!
