Hi to all,
when i try to install android x86 on virtualbox (i tried with vmware too), there is an error: Every time I press a key on the keyboard it is as if I pressed it more than once, So i can not do any operation, i can not even go ahead in the installation procedure. I've tried installing old versions of android x86 and older versions of virtualbox but without any results. Have any of you already had this problem?
